Rigid-Flex pcb modal analysis
    • BALA
      Hello all, I am performing modal analysis of pcb where two rigid PCBs are connected by flex pcb. I want to know how can I model this flex pcb part in mechanical like can I just consider stiffness ... what is the way to model these type of PCBs in ansys mechanical?
    • Sampat Kumar
      Hi Bala,
      you can select a rigid body under the stiffness behavior in the detail of geometry.
      Best Regards,
      Sampat
  • The topic ‘Rigid-Flex pcb modal analysis’ is closed to new replies.
