September 18, 2018 at 3:49 pm
israrullah69
Subscriber -
September 18, 2018 at 3:58 pm
Sandeep Medikonda
Ansys EmployeeHello, This is not something we do on the student community. Please post images and description of your problem and the errors you are seeing, we can then provide suggestions and help you.
September 19, 2018 at 1:24 am
israrullah69
SubscriberSir I have seen your profile. You are expert. I want to send you my ansys file_first.wbpz. Please check and help.
Regards
September 19, 2018 at 1:36 am
peteroznewman
SubscriberHello Israrullah,
I see you have done some work since you first posted. I see there is a working model and you have results, so you did something right. In looking at your geometry, I see you would have five joints. I expect to see one fixed joint, 3 revolute joints and one translational joint, so that seems correct.
You say you don't get the desired results. What results were you expecting?
Some possible sources of error are (1) The mass (or moment of inertia) of the bodies does not match the problem specification, (2) the direction of gravity does not match the problem specification. (3) The sign on the velocity does not match the problem specification.
I downloaded your attached Workbench Project Archive .wbpz file, but you must be using ANSYS 19.2 because I can't open the archive as I am on ANSYS 19.1 today.
Please reply with details on why you think your model is wrong.
Peter
September 19, 2018 at 1:45 am
israrullah69
Thanks. Now it works. Yes I am using ANSY 19.2. Thanks a lot. I have attached correct model for study by others.
- The topic ‘Rigid Body Dynamics help needed’ is closed to new replies.
4763
1565
1386
1242
