March 18, 2025 at 2:02 pm
caspargutsche1
SubscriberFor some reason the top ribbon of my ansis fluent does not show any more. Its unclear why. In the right click menu the ribbon is also grayed out.Â
I am using ansys on Arch Linux.
Here is the transkript from opening the file:
Opening input/output transcript to file "/popos/home/caspar/Documents-old/code/CFD/Exercise-3/fluent-20250318-145532-13218.trn". Auto-Transcript Start Time: 14:55:32, 18 Mar 2025 /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/bin/fluent -r24.2.0 2ddp -pdefault -host -alnamd64 -t4 -mpi=intel -path/home/caspar/Programs/Ansys/ansys_inc/v242/fluent -ssh -cx framework:38007:41087 Starting /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/lnamd64/2ddp_host/fluent.24.2.0 host -cx framework:38007:41087 "(list (rpsetvar (QUOTE parallel/function) "fluent 2ddp -flux -node -alnamd64 -r24.2.0 -t4 -pdefault -mpi=intel -ssh") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "4") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) "/home/caspar/Programs/Ansys/ansys_inc/v242/fluent") (rpsetvar (QUOTE parallel/hostsfile) "") (rpsetvar (QUOTE gpuapp/devices) ""))" Welcome to ANSYS Fluent 2024 R2 Copyright 1987-2024 ANSYS, Inc. All Rights Reserved. Unauthorized use, distribution or duplication is prohibited. This product is subject to U.S. laws governing export and re-export. For full Legal Notice, see documentation. Build Time: May 13 2024 11:01:44 EDT Build Id: 10192 Connected License Server List: 1801@lic-ansys-teaching.ethz.ch -------------------------------------------------------------- This is an academic version of ANSYS FLUENT. Usage of this product license is limited to the terms and conditions specified in your ANSYS license form, additional terms section. -------------------------------------------------------------- Host spawning Node 0 on machine "framework" (unix). /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/bin/fluent -r24.2.0 2ddp -flux -node -alnamd64 -t4 -pdefault -mpi=intel -ssh -mport 10.5.178.28:10.5.178.28:40135:0 grep: warning: stray \ before / grep: warning: stray \ before / Starting /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/multiport/mpi/lnamd64/intel2021/bin/mpirun --rsh=ssh -f /tmp/fluent-appfile.caspar.13769 -genv I_MPI_FABRICS shm -genv FLUENT_ARCH lnamd64 -genv I_MPI_DEBUG 0 -genv I_MPI_ADJUST_GATHERV 3 -genv I_MPI_ADJUST_ALLREDUCE 2 -genv I_MPI_PLATFORM auto -genv PYTHONHOME /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/../../commonfiles/CPython/3_10/linx64/Release/python -genv FLUENT_PROD_DIR /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0 -genv FLUENT_AFFINITY 0 -genv I_MPI_PIN enable -genv KMP_AFFINITY disabled -n 4 /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/lnamd64/2ddp_node/fluent_mpi.24.2.0 node -mpiw intel -pic shmem -mport 10.5.178.28:10.5.178.28:40135:0 ----------------------------------------------------------------------------------- ID Hostname Core O.S. PID Vendor ----------------------------------------------------------------------------------- n0-3 framework 4/8 Linux-64 13837-13840 11th Gen Intel(R) Core(TM) i5-1135G7 host framework Linux-64 13430 11th Gen Intel(R) Core(TM) i5-1135G7 MPI Option Selected: intel Selected system interconnect: shared-memory ----------------------------------------------------------------------------------- Cleanup script file is /popos/home/caspar/Documents-old/code/CFD/Exercise-3/cleanup-fluent-framework-13430.sh In the absence of hardware-accelerated drivers, the performance of all graphics operations will be severely affected. Make sure you have a supported graphics card, latest graphics driver, and a supported remote visualization tool with direct server-side rendering enabled. If you feel your system meets these requirements, try forcing the accelerated driver by using the command line flag (-driver ) or setting the HOOPS_PICTURE environment variable. Refer to the documentation for more details. WARNING: Rank:0 Machine framework has 35 % of RAM filled with file buffer caches. This can cause potential performance issues. Please use -cflush flag to flush the cache. Reading "/home/caspar/Documents/Studium/Caspars Volt/Computational Fluid Dynamics/exercises/Exercise-3/r2.cas"... Buffering for file scan... 4200 quadrilateral cells, zone 2, binary. Warning: reading 2 partition grid onto 4 compute node machine; will auto partition. 4200 cell partition ids, zone 2, 2 partitions, binary. 8245 2D interior faces, zone 3, binary. 120 2D axis faces, zone 4, binary. 190 2D wall faces, zone 5, binary. 4356 nodes, binary. 4356 node flags, binary. Building... mesh auto partitioning mesh by Metis (fast), distributing mesh parts...., faces...., nodes...., cells...., bandwidth reduction using Reverse Cuthill-McKee: 31/30 = 1.03333 materials, interface, domains, mixture zones, wall-5 axis-4 interior-3 fluid parallel, Information: This case file was set up in version 20.2 using a mass flux formulation that is now referred to as Rhie-Chow: distance based. In this release, you now have additional options from which to choose that may be preferable, including Auto Select and Rhie-Chow: momentum based. You can set the formulation using the following text command: solve/set/flux-type. Done. > Opening input/output transcript to file "/popos/home/caspar/Documents-old/code/CFD/Exercise-3/fluent-20250318-145532-13218.trn". Auto-Transcript Start Time: 14:55:32, 18 Mar 2025 /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/bin/fluent -r24.2.0 2ddp -pdefault -host -alnamd64 -t4 -mpi=intel -path/home/caspar/Programs/Ansys/ansys_inc/v242/fluent -ssh -cx framework:38007:41087 Starting /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/lnamd64/2ddp_host/fluent.24.2.0 host -cx framework:38007:41087 "(list (rpsetvar (QUOTE parallel/function) "fluent 2ddp -flux -node -alnamd64 -r24.2.0 -t4 -pdefault -mpi=intel -ssh") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "4") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) "/home/caspar/Programs/Ansys/ansys_inc/v242/fluent") (rpsetvar (QUOTE parallel/hostsfile) "") (rpsetvar (QUOTE gpuapp/devices) ""))" Welcome to ANSYS Fluent 2024 R2 Copyright 1987-2024 ANSYS, Inc. All Rights Reserved. Unauthorized use, distribution or duplication is prohibited. This product is subject to U.S. laws governing export and re-export. For full Legal Notice, see documentation. Build Time: May 13 2024 11:01:44 EDT Build Id: 10192 Connected License Server List: 1801@lic-ansys-teaching.ethz.ch -------------------------------------------------------------- This is an academic version of ANSYS FLUENT. Usage of this product license is limited to the terms and conditions specified in your ANSYS license form, additional terms section. -------------------------------------------------------------- Host spawning Node 0 on machine "framework" (unix). /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/bin/fluent -r24.2.0 2ddp -flux -node -alnamd64 -t4 -pdefault -mpi=intel -ssh -mport 10.5.178.28:10.5.178.28:40135:0 grep: warning: stray \ before / grep: warning: stray \ before / Starting /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/multiport/mpi/lnamd64/intel2021/bin/mpirun --rsh=ssh -f /tmp/fluent-appfile.caspar.13769 -genv I_MPI_FABRICS shm -genv FLUENT_ARCH lnamd64 -genv I_MPI_DEBUG 0 -genv I_MPI_ADJUST_GATHERV 3 -genv I_MPI_ADJUST_ALLREDUCE 2 -genv I_MPI_PLATFORM auto -genv PYTHONHOME /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/../../commonfiles/CPython/3_10/linx64/Release/python -genv FLUENT_PROD_DIR /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0 -genv FLUENT_AFFINITY 0 -genv I_MPI_PIN enable -genv KMP_AFFINITY disabled -n 4 /home/caspar/Programs/Ansys/ansys_inc/v242/fluent/fluent24.2.0/lnamd64/2ddp_node/fluent_mpi.24.2.0 node -mpiw intel -pic shmem -mport 10.5.178.28:10.5.178.28:40135:0 ----------------------------------------------------------------------------------- ID Hostname Core O.S. PID Vendor ----------------------------------------------------------------------------------- n0-3 framework 4/8 Linux-64 13837-13840 11th Gen Intel(R) Core(TM) i5-1135G7 host framework Linux-64 13430 11th Gen Intel(R) Core(TM) i5-1135G7 MPI Option Selected: intel Selected system interconnect: shared-memory ----------------------------------------------------------------------------------- Cleanup script file is /popos/home/caspar/Documents-old/code/CFD/Exercise-3/cleanup-fluent-framework-13430.sh In the absence of hardware-accelerated drivers, the performance of all graphics operations will be severely affected. Make sure you have a supported graphics card, latest graphics driver, and a supported remote visualization tool with direct server-side rendering enabled. If you feel your system meets these requirements, try forcing the accelerated driver by using the command line flag (-driver ) or setting the HOOPS_PICTURE environment variable. Refer to the documentation for more details. WARNING: Rank:0 Machine framework has 35 % of RAM filled with file buffer caches. This can cause potential performance issues. Please use -cflush flag to flush the cache. Reading "/home/caspar/Documents/Studium/Caspars Volt/Computational Fluid Dynamics/exercises/Exercise-3/r2.cas"... Buffering for file scan... 4200 quadrilateral cells, zone 2, binary. Warning: reading 2 partition grid onto 4 compute node machine; will auto partition. 4200 cell partition ids, zone 2, 2 partitions, binary. 8245 2D interior faces, zone 3, binary. 120 2D axis faces, zone 4, binary. 190 2D wall faces, zone 5, binary. 4356 nodes, binary. 4356 node flags, binary. Building... mesh auto partitioning mesh by Metis (fast), distributing mesh parts...., faces...., nodes...., cells...., bandwidth reduction using Reverse Cuthill-McKee: 31/30 = 1.03333 materials, interface, domains, mixture zones, wall-5 axis-4 interior-3 fluid parallel, Information: This case file was set up in version 20.2 using a mass flux formulation that is now referred to as Rhie-Chow: distance based. In this release, you now have additional options from which to choose that may be preferable, including Auto Select and Rhie-Chow: momentum based. You can set the formulation using the following text command: solve/set/flux-type. Done. -
March 18, 2025 at 2:09 pm
Forum ModeratorTry typing   /display/update-layout default into the Console.Â
March 18, 2025 at 2:14 pm
caspargutsche1
SubscriberThanks, that worked : )
March 18, 2025 at 2:11 pm
caspargutsche1
SubscriberIs there maybe some log file that can be found somewhere?
March 18, 2025 at 2:13 pm
Forum ModeratorDidn't the command work? There may not be a log, it depends how you broke it.Â
March 18, 2025 at 2:16 pm
caspargutsche1
SubscriberHi, yes the command worked. I just hadnt seen your reply earlier. Thank you so much.Â
1836
1387
1249
