May 20, 2023 at 10:42 pm
suruchi.bala
SubscriberHi,
Kindly update Spontaneous Four-wave Mixing (SWFM) Microring Resonator Photon Source – Ansys Optics this example, as rib_waveguide.lms file is missing in the zip file and also check if out of effective mode and mode area script, which one has to run for step4.
May 23, 2023 at 4:38 pm
Amrita Pati
Ansys EmployeeHi Suruchi,
Thank you for bringing this to our attention. We will add the file.
Amrita -
June 7, 2023 at 10:36 am
suruchi.bala
SubscriberHi Amrita
When can I expect the updated file?
June 8, 2023 at 12:57 am
Amrita Pati
We have updated the folder. The missing file is now called "waveguide.lms". We have changed the name in the article as well. Thank you again for brining this to our attention.Regards,
Amrita
- The topic ‘Rib waveguide.lms file is missing in SFWM ring resonator example’ is closed to new replies.
Ansys Innovation Space
1118
1063
1055
952
