December 12, 2025 at 9:44 am
rahul159753159
SubscriberHello,
I have created a predefined mixture of fluid in refprop (Version 10.0) to be used in fluent (Version 2025R2). I have the mass fractions and all the .fld files that refprop is using to create the predefined mixture. I don't really know how to create RGP for that. I looked out for this thread How to generate and setup RGP-Tables for CFX multiphase flow simulations but the zip file seems tp be removed/missing. Can anyone help me with this please?
Thanks
December 15, 2025 at 10:11 am
SRP
Ansys EmployeeHi,
You can check user's manual for creating RGP file: 6.1. Real Gas Property (RGP) Table Files
December 15, 2025 at 3:27 pm
jcooper
Ansys EmployeeHi Rahul:
The generic process for creating RGP files uses the ANSYS System coupling application. You supply a Python file with instructions for the mixture and then run from the command line:
"C:\Program Files\ANSYS Inc\v251\SystemCoupling\bin\systemcoupling" -R script.py
The resulting RGP file can be used with either CFX or Fluent.
Below is a sample script for a mixture:
import os
import pyExt.RefProp as arpfluidsPath = arp.getFluidsPath()
mat = arp.RefPropLib()
# Enter mixture components - these all must exist in the material database
#fluidList = arp.FluidList()
fluidList.append("R23.FLD")
fluidList.append("R116.FLD")
# Enter mass ratios of mixture components
composition = arp.Values()
composition.append(0.46)
composition.append(0.54)
matInfo = mat.setmix(fluidsPath, fluidList, composition)
mixInfo = mat.info()
print(
  f"Critical point    : (",
  mixInfo.tempCrit,
  mixInfo.presCrit,
  mixInfo.rhoCrit,
print(
  f"Cricondenbar point  : (",
  mixInfo.psatMaxT,
  mixInfo.psatMax,
  mixInfo.psatMaxD,
print(
  f"Cricondentherm point : (",
  mixInfo.tsatMax,
  mixInfo.tsatMaxP,
  mixInfo.tsatMaxD,
#Set the variable interpError as follows to define an accuracy, may need to adjust
# for convergenceÂ
#Â
#'low' : Â Â Â 1e-3 Â
#'medium': Â Â 1e-4Â
#'med-high' : Â 5e-5 Â Â
#'high' : Â Â Â 2e-5Â
#'very-high' : 1e-5
interpError = 5.0e-5#
#Set table ranges larger than problem range to allow for overshoots
#Tmin = 200.0
Tmax = 500.0
Pmin = 3000
Pmax = 2.4e06#
# generate tables - pass arp.ADAPT_AUTO_TP for 1D tables and arp.ADAPT_AUTO_2D for 2D
#R508BL = arp.RGPLiquid("R508BL", Tmin, Tmax, Pmin, Pmax, interpError, arp.ADAPT_AUTO_TP)
liquid_tab = arp.buildRGPComponent(R508BL)
arp.writeRGPfile("R508BL.rgp", liquid_tab)R508BV = arp.RGPVapor("R508BV", Tmin, Tmax, Pmin, Pmax, interpError, arp.ADAPT_AUTO_TP)
vapor_tab = arp.buildRGPComponent(R508BV)
arp.writeRGPfile("R508BV.rgp", vapor_tab)mat.release()
5274
1885
1403
1262
