September 18, 2019 at 8:43 pm
ttgf1
SubscriberHi,
Is there a way to pause (or interrupt) a mechanical (static or transient) simulation in WB, close all the ANSYS windows, turn the computer off and resume the same model later, without losing the progress?
thanks
September 18, 2019 at 10:02 pm
peteroznewman
SubscriberYes. If you have at least one converged substep, then you can click the interrupt button and save the project. Then you can shut down the computer. After the computer starts and Workbench is started, the project file opened and Mechanical opened, you can set the Analysis setting to Restart the simulation from the last converged substep.
September 18, 2019 at 10:13 pm
ttgf1
Subscriberthanks!
November 11, 2022 at 11:20 am
marco.ballotta.2
SubscriberHello,
where can I find the "Restart the simulation from the last converged substep" in the Analysis settings? I looked up in restart controls but I couldn't find it.
Thank you
June 27, 2023 at 3:42 am
Lawrence Kiser
SubscriberYes, there is a way to pause (or interrupt) a mechanical (static or transient) simulation in Ansys Workbench, close all the ANSYS windows, turn the computer off and resume the same model later without losing the progress. You can click “Interrupt Solution” in the ANSYS Workbench Solution Status window that pops up during solution. This will pause the solution and allow you to look at the results so far. When you are ready to resume the simulation, you can simply click “Resume Solution” in the same window.
- The topic ‘resuming WB simulations’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
4117
1487
1318
1157
