Resuming SAG Mill Simulation with New Particle Batch in Rocky
    • youssef.badran
      I ran a SAG mill simulation with breakage in Rocky for 25 seconds. Now, I’d like to remove the existing particles while preserving the worn geometry and then introduce a new set of particles.
      Could you guide me on how to do this?
    • youssef.badran
      I exported the worn geometry and used it in a new simulation. Even though the wear magnitude at time zero appears as zero (the wear data is lost), the geometry is worn at time zero.
    • Lucas Bertollo Baggio
      Good. It is the same I suggested you to do in the topic: Continuing SAG Mill Simulation with New Particle Batch in Rocky
