May 22, 2023 at 10:16 am
Kent Emmanuel Soria
SubscriberHello,
I cannot obtain the result of my parameter sweep, it is saying that they are of different sizes. The sweeps themselves exist as different files, but my temp sweep here becomes empty after running the simulation. I need that data to save it as a mat file that contains the data of all the sweeps.Â
May 22, 2023 at 10:29 am
Kent Emmanuel Soria
SubscriberThis is in Lumerical HEAT. I don't know what to do I need the data of the sweeps I ran.Â
May 22, 2023 at 10:33 am
Kent Emmanuel Soria
SubscriberOr is there a way to manually get the data of all the sweeps into one?Â
May 23, 2023 at 11:36 pm
Guilin Sun
Ansys EmployeeMost likely it is due to the monitor data size: the mesh or simulation size is changed during the sweep. Please lock the mesh (after mesh generation) and sweep again, if the simulation region does not change.
If the simulation region changes, then the mesh will likely change.
- The topic ‘Results of parameter sweep individual simulation not same size’ is closed to new replies.
5939
1307
