February 2, 2023 at 2:30 pm
Patrickodon
SubscriberHi all,
I've done a run on Ansys and wish to go to the Calculations (as per /forum/forums/topic/how-can-we-measure-the-visocity-of-fluid/). I click Results:
But get the following errors:
My run was quite simple (as per /forum/forums/topic/permanently-changing-the-cell-zones-to-desired-material/). What's causing this, and why can't I view the Results section in Fluent?
February 2, 2023 at 3:10 pm
Forum ModeratorThe workflows can become corrupted, connect a separate Results task to the Solution and see how that behaves. We tend to do all post processing in Fluent, and also the 3d workflow is done outside of Workbench, so Geometry>Fluent Meshing>Fluent.Â
- The topic ‘Results not opening in Fluent’ is closed to new replies.
1587
1386
1242
