results data at the outlet to be input data at the inlet
    • peppers
      I want the temperature results at any time (transient) at the outlet in geometry 1 to be temperature input data at the inlet geometry 2, how do I do that?
    • Supreetha J
      You can make use of Profile file to do this. Kindly refer to the Ansys User's Guide 3.6. Reading and Writing Profile Files (ansys.com)
      If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
      Thank you.
  • The topic ‘results data at the outlet to be input data at the inlet’ is closed to new replies.
