July 13, 2021 at 10:14 am
Mecha
SubscriberHi,
I have a few questions of my 1st simulation in ANSYS fluent.
Problem Description:
See Figure_1. High compressed air is flowing within the annulus and through the "barrier" with an inlet pressure of 1.7 bar or a flow rate ( 283 L/s = 0.283 m^3/s). What is the average velocity in the outlet?
Fluent Setup:
Figure_2 display the setup and velocity result.
Questions:
Setup 1) The results seems a bit extreme in terms of velocity, validating this with the flow rate: Q = AV --> V = Q/A = 0.283/7.21*10^-4 = 392.5 m/s. Which is far from the inlet simulation. I am not used to simulate high pressurised gases so it may very be that this is realistic or am I missing something?
Setup 2) Same setup but switched the pressure inlet to a mass flow inlet. The values dropped drastically but it seems more realistic than setup 1. Shouldn't the pressure and flow rate correspond to the same results?
How do I obtain average velocity or a defined volume average velocity?
For future questions, Which questions is suitable for posting in Discussion VS Questions?
July 13, 2021 at 1:15 pmKarthik Remella
AdministratorHello In your first case, could you check the overall mass flow rate and compare it with that in your second case? I suspect that there is a difference between the two cases and therefore the results are different.
Karthik
July 14, 2021 at 5:55 amMecha
SubscriberAh, you made me think! I assumed that the pressure if 1.7 MPa would be the same as 0.283 m^3/s but it seems like its not the same.
That takes me to the original questoin about how I can obtain a measurement of average velocity or a defined volume average velocity in Fluent?
July 14, 2021 at 7:10 amAmine Ben Hadj Ali
Ansys EmployeeUsing Report definitions you can create an average of velocity at a boundary / Cell zone.
July 14, 2021 at 8:44 amMecha
SubscriberThank you, I think Ive succededJuly 14, 2021 at 11:25 amKarthik Remella
AdministratorExcellent! Good luck with your model!
July 14, 2021 at 12:03 pmAmine Ben Hadj Ali
Ansys EmployeeGreat!.
Viewing 6 reply threads- The topic ‘Results and How To Obtain Outlet or Defined Volume Average Velocity?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3892
1414
1241
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
