October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeWhy are resulting table parameters incorrect after *TOPER command?
October 17, 2017 at 9:56 am
cbhavsar
Ansys EmployeeMake sure the arguments of the TOPER command are correctly passed. For example, when you use ADD as the operation it will be performed as follows; ParR(i,j,k) = FACT1Par1(i,j,k) + FACT2 *Par2(i,j,k) +CON1 Also, it is necessary for both the parameters (ie Par1 and Par2) to have the same dimensions and the same variable names corresponding to those dimensions. Par1 and Par2 must also have identical index values for rows, columns, etc.
- The topic ‘Resulting table parameters are incorrect after *TOPER command’ is closed to new replies.
1520
1386
1209
