November 20, 2023 at 10:21 am
suryakant.koshta
SubscriberIn the given figure because of the buckling due to applied load in -Y direction, highlighted green edge will deform in X direction but i want to deform it upto 30mm in x direction so if i will give displacement boundary condition on this edge, it will capture the actual deformation of this body in case of buckling?
November 22, 2023 at 2:59 pm
Ashish Khemka
Forum ModeratorHi, you can create a rigid surface at a distance of 30mm in the x-direction and define a contact between the edge and surface.
Ashish Khemka
December 14, 2023 at 7:01 am
suryakant.koshta
Subscriberthanks Ashish
- The topic ‘Restricting deformation upto certain length in particular direction’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
1487
1318
1164
