August 17, 2023 at 8:19 pm
August 18, 2023 at 12:31 pm
Aniket Chavan
Forum Moderator -
August 18, 2023 at 12:45 pm
Massochy dos santos Ventura
Subscriberremote help does not work
August 18, 2023 at 12:46 pm
SubscriberDo you have another way for do this
August 18, 2023 at 2:59 pm
Aniket Chavan
Forum Moderatorcan you explain your problem in more details? What do you mean by remote displacements do not work?
-Aniket
August 18, 2023 at 3:03 pm
SubscriberI'm doing a modal analysis of a free-free steel plate and want to restrict the degrees of freedom in the direction UX,UZ,ROTX,ROTY,ROTZ before excuting the solution. whether it's in workbench
August 18, 2023 at 3:40 pm
peteroznewman
SubscriberDon't call it a free-free modal analysis if you restrict degrees of freedom.
Is that a shell model with thickness turned on or is it a solid model with one element through the thickness?
August 18, 2023 at 3:44 pm
SubscriberIs a shell model with thickness turned on
August 18, 2023 at 3:54 pm
SubscriberI'm doing a modal analysis on a free-free steel plate in order to extract stiffness matrix, mass matrix and the vectors corresponding to the vibration modes for each natural frequency. in order to reduce the values ​​of the matrices so I intend to restrict some degrees of freedom since the matrix is ​​formed by the multiplication between numbers of nodes and the degrees of freedom (in this case they are 6)
August 18, 2023 at 4:08 pm
SubscriberI'm doing a modal analysis on a free-free steel plate in order to extract stiffness matrix, mass matrix and the vectors corresponding to the vibration modes for each natural frequency. in order to reduce the values ​​of the matrices so I intend to restrict some degrees of freedom all nodes since the matrix is ​​formed by the multiplication between numbers of nodes and the degrees of freedom (in this case they are 6)
August 18, 2023 at 4:13 pm
- The topic ‘restrict the degrees of freedom’ is closed to new replies.
5639
1885
1403
1303
