March 12, 2020 at 7:01 am
March 12, 2020 at 7:15 am
Aniket
Forum Moderatorplease review the guidelines before posting a question. You can find them in my signature for easy access. Also Ansys staff can not access the attachments on the community so please use the ‘Insert Image’ option to share your images. Please refrain from using the ‘Attach’ option as much as possible.
-Aniket
March 12, 2020 at 7:28 am
Chinmay
SubscriberHi,
Thank you for your response, I have read all the guidelines on student community and edited my post accordingly.
March 12, 2020 at 7:52 am
Aniket
Forum Moderatorhave you defined a frictional contact at the following location highlighted in red and green?
-Aniket
March 12, 2020 at 8:03 am
Chinmay
SubscriberNo, I haven't. I will go with edge (red) and area (green) contact and I think that will do it. Thanks a lot. Will let you know soon.
March 12, 2020 at 8:09 am
Aniket
Forum Moderatoranticipating contact will be face to face due to deformation instead of edge to face, Go for face to face contact instead.
March 12, 2020 at 8:16 am
Chinmay
SubscriberI can't add Edge and Face contact at a time ? I anticipated that the edge will rub first and then the area might come in contact (not sure though, will have to check). I have around "8 faces and 2 Edges" on contact and "8 face" contacts on target. I am not able to select face and edge simultaneously. Thanks.
March 12, 2020 at 9:22 am
Chinmay
Subscriber Hi, I tried the method you suggested. It restricted deflection beyond the metal surface but unfortunately it started with that area in contact. I need the tongue to deflect during insertion but the tongue shouldn't cross boundaries. My apologies, I should have mentioned this at the start of this discussion. I found following result.
The yellow (bow shape) marked is undesirable, Green and Red faces were taken to be in contact. I need to take edge contact for green and face contact for red but it seems it will give similar result. Should I add another manual contact along with previous ones ?
Thanks. Any suggestion is most welcome.
March 12, 2020 at 10:49 am
Aniket
Forum ModeratorSorry what's the exact issue here? It does seem to behave as expected here to me! Am I missing something?
-Aniket
March 13, 2020 at 3:17 am
Chinmay
SubscriberYes Sorry, my bad. It's behaving at it should the only amendment was to provide edge contact to face contact. Thanks for your solution. You're awesome. Much obliged.
- The topic ‘Restrict deformation to a limit’ is closed to new replies.
4683
1565
1386
1242
