May 31, 2024 at 9:08 am
June 5, 2024 at 12:08 pm
V.P
Ansys EmployeeHi Iden,
This happens because the topologies are not shared. Use the "Share topology" option in SpaceClaim/DesignModeller/Discovery and then import the geometry into meshing. Or else if you are using Fluent meshing, there is an option to share the topologies at the 'Describe Geometry' step.
- The topic ‘Resolving Mesh Connectivity Issues Between Two Part Bodies’ is closed to new replies.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
1494
1376
1209
