October 10, 2024 at 8:23 am
chrsa
SubscriberI want to calculate the powercouplinng coefficient for a ring coupled to a waveguide. As I want to simulate an anisotropically etched wavguide I choose a waevguide object similar to the ring modulator example. For medium rings (d = 300 µm left) the result seems to be more or less resonable (d = 300 µm, gap = 1µm Wavguide ~1.0 µm, lambda ~1.55), while for bigger rings (d = 900 µm, gap = 1µm Wavguide ~1.5´0 µm, lambda ~1.55) it looks, as if the ring consist of a wavguide with sharp bends simialar to the low resolution rendering.
October 10, 2024 at 4:31 pm
Guilin Sun
Ansys EmployeeYou can use ring object and modify the starting and stop angles to create the arc.
Bezier https://optics.ansys.com/hc/en-us/articles/360034382234-Waveguide-Simulation-Object
https://optics.ansys.com/hc/en-us/articles/360034901673-Tips-for-creating-waveguide-bends-using-the-path-object
Once the Bezier bend chooses the order, the number of points is fixed. and the curve should be smooth.
October 14, 2024 at 9:14 am
chrsa
SubscriberDear Guilin,
sure I could use a ring object for a ring, but sadly the ring object does not provide any non 90 degree sidewall angle. Regadring the Bezier - I also belive it should be smoth but somehow it is not for big objects.
Do you have any other suggestions? I assume I could use a polygon and extrude it along a circular path. But is there any simpler solution than that?
Christian
October 14, 2024 at 5:01 pm
Guilin Sun
Ansys EmployeeThe Bézier-curve has analytical expressions once the spans are known.
You may try to explore from where it begins showing issue. You may file a feature request at ix. https://ix.lumerical.com/
You may try to use other methods to create the side wall. For example layered ring, or N-sided polygon toroid in the structure library, or planar solid: https://optics.ansys.com/hc/en-us/articles/360034901573-Planar-solid-Simulation-Object
5674
1890
1419
1304
