TAGGED: CFD-Solver, residuals, supersonic, supersonic-flow
September 16, 2023 at 7:55 am
felice_lucivero
SubscriberHello everybody,
I am trying to simulate a supersonic flow throguh an air intake.
The final aim of the project is to reproduce the results reported in a reference paper, but my residuals are not converging.
The mesh I have used for the simulation is the following:
The density-based (coupled) implicit double precision Fluent solver has been set.
For the inlet I set a farfield bc with a Mach number equals to 2.41.
For the outlet I set a pressure-outlet bc with zero pressure.
The CFL was fixed at 0.5.
All of these conditions come from the reference paper.
I have also tried to switch to a pressure-based solver, but the solution get even worse.
What might be the issue?
September 18, 2023 at 1:19 pm
felice_lucivero
SubscriberNobody's got any idea?
September 20, 2023 at 12:38 pm
Essence
Ansys EmployeeHello,
Which turbulence model did you use? What are the controls (URFs) you set? Reduce the URFs and once stable residuals reached, turn them to default. Use FMG initialization. Also for higher order terms of discretization, please use High Order Term Relaxation (HOTR) for stable residuals. Use Psuedo time step.
September 25, 2023 at 11:03 am
felice_lucivero
SubscriberHello Essence,
I used a RNG k-e model. This choice is in accord with the reference paper, I need to simulate that model for having a comparison with my results.
I tried what you suggested and, besides that, I also lowered the order of the numerical methods (from 2nd to 1st order upwind).
Nevertheless, there was no big improvement in the residuals:
I brought the URFs gradually down to 0.1.Is it possible that there might be a problem with the BCs?
September 25, 2023 at 2:42 pm
Essence
Ansys EmployeeDid you use FMG initialization? Initial values in compressible flows play important role in convergence.
September 26, 2023 at 3:39 pm
felice_lucivero
SubscriberYes, I did use FMG initialization but I did not change any parameter, I left everything as default.
October 9, 2023 at 1:38 pm
felice_lucivero
SubscriberMy residuals are still not converging, anyobody's got any idea?
October 9, 2023 at 4:17 pm
Forum ModeratorPlease refer to the various comments in your other threads regarding your mesh and other settings.Â
- The topic ‘Residuals not converging (2D supesonic inlet)’ is closed to new replies.
5824
