Residuals contours
    • felice_lucivero
      Hello everybody,
      I am running a 2D simulation in Fluent, but I am facing some troubles with convergence.
      I would like to plot the residuals contours to spot where the problem is.
      There exists any way to do this?
      You can't plot the residuals (good idea though). Mass balance is available in the contour plots, focus more on the high/low parts of the scale over the values.
      Depending on what is causing the problems I also suggest looking at velocity and temperature contour plots with node values on and then off. You're looking for badly resolved gradients.
      How are the monitors looking?
    • felice_lucivero
      Hello Rob,
      where can I find the mass balance in the contour plots?
      Here is a close up of the highest temperture gradients within the domain:
      Here is the velocity contour plot:
      Just to give you an idea.
      Thank you
      In the Residuals bit, Mass Imbalance, so I was nearly right.
      Looking at the images I'd focus attention on the blue "lines" in the top image and green-ish line in the lower: there's an obvious streak in the results.
  • The topic ‘Residuals contours’ is closed to new replies.
