Residuals are converging and then jump up to 1e+00
    • Zwernjayden
      Any idea why this might be happening? I am using eddy dissipation concept model and dpm sources. First image is when i tried steady state, 2nd is when i tried transient analysis.
    • SRP
      Can you try to use the steady results as a initial guess for the transient simulation?
      • Zwernjayden
        Im only really interested in the steady case, I just showed both so that it was clear I was having an issue with both steady and transient
