September 27, 2017 at 11:19 am
admin
Ansys EmployeeHow can I reset the residuals?
October 17, 2017 at 6:24 am
admin
Ansys EmployeeTo continue the calculation with reset residuals, will use the following TUI command: /solve/monitors/residual/reset? yes
November 2, 2018 at 1:52 am
Jamessmp23
SubscriberHi, I've read someone said using the TUI command: /solve/monitors/residual/reset just reset only on the display but the data still not reset.Â
Do you already solved this problem ? Can anyone explain more about this ?
Thanks,
JamesÂ
November 2, 2018 at 6:11 am
Amine Ben Hadj Ali
Ansys EmployeeIt will reset the residual data -
November 2, 2018 at 10:11 am
Forum ModeratorTo add, if you need to reset the solution data you just re-initialise the model. It's very rare that we reset the residuals, but resetting the monitors (the command is in there somewhere too) is done more often when looking at cyclic transient simulations.Â
November 19, 2018 at 6:37 am
seeta gunti
Ansys EmployeeAs James and others mentioned, by resetting the residuals, it will only reset the residuals to zero but it won't reset the data. Even you reset the residuals, you can still post-process the data. If you want to reset the data, better you can re-initialize the solution and continue the calculation.
- The topic ‘Reset the residuals’ is closed to new replies.
4673
1565
1386
1231
