October 21, 2024 at 12:50 pm
gopalakrishna.gangisetty
SubscriberI have a skylight for roof top modeled with two different materials
1.       regular window glass which is opaque for longwave radiation.
2.      ZnS glass is 75% (0.75) transparent to the longwave radiation.
I used Discrete Ordinates (DO) Model since it is the only model with 'semi-transparent' and 'non-gray' mode.Â
I made four bands, 0 – 4, 4 – 8, 8-14, 14-50 µm in Model - Radiation - Number of Bands,
Let’s assume that :
Topside window glass and top side ZnS glass are exposed to ambient surroundings at 296 K
bottom side window glass and bottom side ZnS glass are located inside building space at 298 K
Now, I turned on solar calculator,
- Input the data such as Latitude, longitude, time, and data, (this is fine).
Direct solar irradiation as 660 W/m2
Diffuse solar irradiation as 125 W/m2
Then, I turned on solar BC options for both top side window glass (opaque for long wave radiation) and top side ZnS glass (75% transparent for long wave radiation),Â
Question: for top side window glass, direct and diffuse irradiation values are already calculated by Ansys software? Â But, to obtain direct and diffuse irradiation for top ZnS glass (tau = 0.75)?
Direct irradiation values for top ZnS multiply with 0.75 ? can you please clarify?Â
I think, Diffuse fraction = Diffuse irradiation/(direct irradiation + diffuse irradiation).
Now, one more question is, based on top side window boundary conditions -Â
For bottom side window glass, for bottom side ZnS glass, I want to set
Direct irradiation = ? Perhaps it is zero in all bands´(1 to 4)
Diffuse irradiations = band 1 to band 4 = (need help here).
Diffuse fraction= band 1 to band 4 = (need help here).Â
Please find the attached screen shots for better idea.
Thank you in advance, evferyone !Â
October 21, 2024 at 12:58 pm
Forum ModeratorDuplicate  https://innovationspace.ansys.com/forum/forums/topic/help-needed-solar-calculator-solar-bc-boundary-conditions/
October 21, 2024 at 1:01 pm
SubscriberDear Sir,
I am sorry for duplicate the same question, my sincere apologies.Â
But, I would request you or someone can help me to understand the boundary conditions please.Â
Thank youÂ
October 21, 2024 at 1:04 pm
Forum ModeratorIt's in the system - any unanswered questions are flagged and will be answered.Â
5824
