June 27, 2023 at 5:03 pm
Dr Fatima Razavi, PhD in MEC ENG
SubscriberDear Community Members,
ÂI hope this message finds you in good health and high spirits.ÂÂI have attached a script file, which functions appropriately as a *.cse file when executed through "play a session" in CFX-post. However, I require assistance in making it iterative so that it can load 120 timesteps and export each timestep as a separate CSV file. Despite my attempts to achieve this by installing Padre and familiarizing myself with Perl scripting, I have been unable to find a satisfactory solution.ÂTherefore, I kindly request your support in making this script iterative. The attached file functions correctly, but as soon as I introduce a loop, it fails to execute properly.ÂÂIn light of these challenges, I believe attending a workshop on scripting/automation in CFD would greatly benefit me. While I am proficient in Unix Bash Scripting, I recognize the need to expand my knowledge in this area.ÂThank you for your attention to this matter. I sincerely appreciate your assistance.ÂWarm regards,Fatemeh.
---------------------------------------------------------------------------------# Session file started: 2023/06/20 11:37:39# CFX-21.2Â# To avoid unnecessary file pre-processing and modifications, include# COMMAND FILE at the top of your session file.# If it is not included, the file is assumed to be older and will be# modified for backward compatibility.COMMAND FILE: CFX Post Version = 21.2ENDÂÂPLANE:Plane 1 Apply Instancing Transform = On Apply Texture = Off Blend Texture = On Bound Radius = 0.5 [m] Colour = 0.75, 0.75, 0.75 Colour Map = Default Colour Map Colour Mode = Variable Colour Scale = Logarithmic Colour Variable = Ragweed.Averaged Volume Fraction Colour Variable Boundary Values = Conservative Culling Mode = No Culling Direction 1 Bound = 1.0 [m] Direction 1 Orientation = 0 [degree] Direction 1 Points = 10 Direction 2 Bound = 1.0 [m] Direction 2 Points = 10 Domain List = /DOMAIN GROUP:All Domains Draw Contours = Off Draw Faces = On Draw Lines = Off Instancing Transform = /DEFAULT INSTANCE TRANSFORM:Default Transform Invert Plane Bound = Off Lighting = On Line Colour = 0, 0, 0 Line Colour Mode = Default Line Width = 1 Max = 0.0 Min = 0.0 Normal = 1 , 0 , 0 Number of Contours = 11 Option = XY Plane Plane Bound = None Plane Type = Slice Point = 0 [m], 0 [m], 0 [m] Point 1 = 0 [m], 0 [m], 0 [m] Point 2 = 1 [m], 0 [m], 0 [m] Point 3 = 0 [m], 1 [m], 0 [m] Range = Global Render Edge Angle = 0 [degree] Specular Lighting = On Surface Drawing = Smooth Shading Texture Angle = 0 Texture Direction = 0 , 1 , 0 Texture File = Texture Material = Metal Texture Position = 0 , 0 Texture Scale = 1 Texture Type = Predefined Tile Texture = Off Transform Texture = Off Transparency = 0.0 X = 0.0 [m] Y = 0.0 [m] Z = 1.6 [m] OBJECT VIEW TRANSFORM:  Apply Reflection = Off  Apply Rotation = Off  Apply Scale = Off  Apply Translation = Off  Principal Axis = Z  Reflection Plane Option = XY Plane  Rotation Angle = 0.0 [degree]  Rotation Axis From = 0 [m], 0 [m], 0 [m]  Rotation Axis To = 0 [m], 0 [m], 0 [m]  Rotation Axis Type = Principal Axis  Scale Vector = 1 , 1 , 1  Translation Vector = 0 [m], 0 [m], 0 [m]  X = 0.0 [m]  Y = 0.0 [m]  Z = 0.0 [m] ENDENDÂ# Sending visibility action from ViewUtilities>show /PLANE:Plane 1, view=/VIEW:View 1Â##################> load timestep=35388ÂEXPORT: ANSYS Export Data = Element Heat Flux ANSYS File Format = ANSYS ANSYS Reference Temperature = 0.0 [K] ANSYS Specify Reference Temperature = Off ANSYS Supplemental HTC = 0.0 [W m^-2 K^-1] Additional Variable List = BC Profile Type = Inlet Velocity CSV Type = CSV Case Name = Case 2nd3min7ms Export Connectivity = Off Export Coord Frame = Global Export File = E:/Fatemeh (Live Runs)/BEST CFD Runs/2023-06-05-Transient-\8Diff-4PartInj-FansSQ-0TO180-7ms/2023-06-05-ExhaustsOnWall-8SwirrlDiffON-\4Aerosolizers-FansFwBw7msSynchronized-FansSQ_003/CSV Files/348.csv Export Geometry = On Export Location Aliases = Export Node Numbers = Off Export Null Data = On Export Type = Generic Export Units System = Current Export Variable Type = Current External Export Data = None Include File Information = Off Include Header = On Location = CeilingWall Location List = /PLANE:Plane 1 Null Token = null Overwrite = On Precision = 8 Separator = ", " Spatial Variables = X,Y,Z Variable List = Ragweed.Averaged Volume Fraction Vector Brackets = () Vector Display = ScalarEND>export -
June 29, 2023 at 9:29 am
Forum ModeratorWe can't cover scripting in much detail, but...
Check the CFD Post documentation or CFX Reference manual section on power syntax. You can embed perl statements in a .cse file. Any line starting with an ! is interpreted as a perl statement. Italics as a colleague told me - I don't use CFX.Â
What we have done before is to create a couple of dummy models. Create a report (in CFD Post) for the first model, then read the new case (same geometry but different file name) into CFD Post & update the report. The state file should give you the command syntax, repeat & then modify to suit the real model. For 120 models you may want to borrow a student or write a Python/AWK script to generate the full journal but that depends on how complex the Perl bit is.Â
- The topic ‘Request for Assistance in Making Script Iterative in CFX-post’ is closed to new replies.
