request for assistance
    • franciscogeff
      please someone should help me interpret this results.
    • Fernando Torres
      What do you mean by interpret ? You have solved the systems for strain energy and deformation respectively. Structure is some reinforced type. Maximum and minimum values are given on scale with colors so that you can find out the regions with maximum "bear". Rest Sir Peter will answer you. Until then take this info as hint
  • The topic ‘request for assistance’ is closed to new replies.
