October 9, 2023 at 1:46 am
AHMED ALI
SubscriberHello all,
I'm simulating humidity. I have created a RH report during calculation which showed me the value in % (around 100%). However, in CFD-post it gave me the value in small number range from zero to 1. How can I display it in percentage? (the plot and the contoure are for the same plane)
Regards
October 9, 2023 at 8:55 am
Forum ModeratorYou may need a custom function. Note, RH can exceed 100% as it's a ratio and you'll not see any condensation unless you switch on the multiphase with phase change models.Â
- The topic ‘Relative humidity unit’ is closed to new replies.
