May 1, 2024 at 4:31 pm
hfarg001
SubscriberHI,
I am trying to model RC for non-linear static analysis. The boundary condition and forces are well defined as well goes for the geometry. Also, the quality of the mesh is perfect with hex8 element multizone. I did a linear analysis and it gave excellent results. Anyway, when I use the Menetry Wiliam model to represent the concrete and UHPC with exponential softening to do non-linear analysis. I used line bodies for reinforcement with bi-linear plasticity The model stops converging and it seems it fails when it reaches it is tensile strength and then stops converging without showing it is softening curve. After trying everything still the model did not get through. My guess of the problem that concrete does not transfer stress with the steel and the reinforcement option is not working for some reason. Could anyone please help me with this issue?? It drove me crazy without being able to fix it at all and I am now considering to use another software because of that issue.Â
Note: I used a small cubic test for plain concrete with menetry wiliam model and it gave the perfect result without having any issue in convergence. So the material should be also well-defined.Â
May 8, 2024 at 8:16 am
Ashish Khemka
Forum ModeratorHi,
Can you please check the following video on YouTube that may be solving the similar setup as you described above:
 Reinforced Concrete Modeling - FEA using ANSYS - Lesson 9 (youtube.com)
Ashish Khemka
May 10, 2024 at 1:51 am
hfarg001
SubscriberI still was not able to fix the issue. Can anyone help me through this matter?
I already learned abaqus and I will run the analysis in there. I do not want my work on Ansys to be a waist of time and I need help because I am out of any option. I want to validate my result using both software.Â
- The topic ‘Reinforced Concrete’ is closed to new replies.
6269
