February 6, 2024 at 2:28 pm
deepesh.p.gurdasani
SubscriberAn error comes like 'Element (element number) has a radius/thickness ratio of (some no.). This violates assemption of shell element.' I tried changing the mesh but still same error pops up and the solution stops.
Can anyone guide how to get this error removed/resolved ?Â
Thanks in advance
February 8, 2024 at 4:39 am
Aniket
Forum Moderator -
February 11, 2024 at 5:28 am
deepesh.p.gurdasani
SubscriberI have edited the query again and also replying it here:
Thanks in advance
February 12, 2024 at 3:20 pm
Ashish Khemka
Forum ModeratorHi,
Please try using a different mesh size.
Also, please see if the following link helps:Â
Ashish Khemka
February 12, 2024 at 4:48 pm
deepesh.p.gurdasani
SubscriberTried using different mesh size but still the same error.
February 13, 2024 at 6:50 am
Aniket
Forum ModeratorÂ
To expand on what Gary and Ashish have said:
The issue is happening due to the Warping of the shell elements and coming due to inadequately defined mesh, there are multiple ways to overcome this
- Use linear mesh
- Refine the mesh in the region where reported warping is high
- Use a SOLVE,,,,,NOCHECK command to ignore the error (last resort)
To know about the issue please refer to this link
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v241/en/ans_elem/Hlp_E_ShellElements.html%23d0e14315https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/ans_thry/thy_et7.html%23eltwarping
-Aniket
February 12, 2024 at 7:05 pm
Gary_S
Ansys EmployeeHi Deepesh
 Try adjusting the Thickness in the Surface body details.Â
 Also, can you show an image of your model?
- The topic ‘Regarding radius/thickness ratio’ is closed to new replies.
4618
1530
1386
1209
