July 24, 2020 at 10:17 am
das.3
SubscriberDear All,Â
I am trying to perform simulation of a radiation problem in an enclosure filled with air and dust particles. The enclosure has a cylindrical shape(dia=0.025 mm, length=500 mm) and external radiation comes in from the circular cross-section and has a conical profile. Please refer to the image attached for a better understanding of the problem. I am using the discrete ordinates radiation to model the physics. I have set the following parameters in the Fluent Software:
Theta, Phi Divisions: 8
Theta, Phi Pixels: 4
Beam Width: 1e-5(both theta and phi)
Beam Direction:Â (1 0 0)
Diffuse fraction: 0
However, the beam that I am getting not what I had expected, The red contours in the figures when matched gives a perfect conical profile, however, the neighboring green and blue contours are unnecessary and I want to get rid of it. I tried to play with the above parameters but no improvement was observed. Looking forward to your support.
Subham Das
- The topic ‘Regarding Problem in Discrete Ordinates Radiation Modeling in Ansys Fluent’ is closed to new replies.
5014
1682
1387
1248
