March 27, 2021 at 12:32 pm
sachintom1992
SubscriberFor transient flow boiling simulations (time step size ~ O(10^-4 s) using the Eulerian model which is the better choice for pressure velocity coupling? nIs the Phase coupled SIMPLE algorithm or Coupled algorithm?Regards,nJosephn -
March 29, 2021 at 10:25 pm
Rahul Kumar
Ansys EmployeeHello, nI would suggest the coupled solver. n -
March 30, 2021 at 4:56 am
sachintom1992
SubscriberSir,n Any specific reason?n I have seen in forums for transient case simulations with small-time step size phase coupled SIMPLE is preferred whereas for steady state case and transient cases with large time step size only coupled solver is preferrable. Is it right?.Regards,nJosephn -
March 30, 2021 at 5:26 am
Amine Ben Hadj Ali
Ansys EmployeeAll solvers should result, when converged, in the same results. That is the ideal! However each schemes might be prone to some issues.nFor long transients I usually prefer using SIMPLEC or PISO because they are cheaper than Coupled but the Coupled solver is usually the way to go: that is the solver which I apply with closed eyes. n -
March 30, 2021 at 5:27 am
Amine Ben Hadj Ali
Ansys EmployeeFor multiphase the coupling is bit tough: for that reason I usually rely on Phase Coupled Simple in Fluent. In CFX I rely more on Fully Coupled: this is based on my experience with the solvers.n -
March 30, 2021 at 5:51 am
sachintom1992
SubscriberSir,n Thanks for your reply.nCan you please clarify this?nI want to write a UDF for the interphase drag coefficient for the bubbly flow regime in ANSYS Fluent 2021 R1.n what is the actual term that has to go into the Fluent code for drag coefficient?nIs It Ai*Cd?nWhere Ai: Interfacial Area and Cd: Drag coefficientnRegards,nJosephn -
March 30, 2021 at 8:31 am
Amine Ben Hadj Ali
Ansys EmployeeIt is Kpq.n
Viewing 6 reply threads
- The topic ‘Regarding pressure velocity coupling for transient flow boiling simulations using Eulerian Eulerian’ is closed to new replies.
- affinity not set
1487
1318
1156
