Regarding Injection for Modeling film cooling in turbine blade
    • rohitroxkp7
      I am trying to model the film cooling of a clean flow profile on which I have already performed simulation. In a recent search, I made regarding the same, I learned that film cooling holes need not be modeled in the physical domain but can instead be modeled using an injection approach. I read this on a white paper published by the ansys community which I have attached in this post below.
      However, I am unable to locate the injection panel and many other details given in the paper. Further, the white paper makes no mention of FLuent. So is this available in a different software of ANSYS? Please help me out and give me some pre cursors to using this Injection approach.
      Best Regards,
      Rohit.
      https://www.ansys.com/content/dam/product/fluids/fluent/modeling-film-cooling-turbine-blade-design.pdf
    • Amine Ben Hadj Ali
      The white paper is related to Ansys CFX.
      With Ansys Fluent you might look after Perforated Walls (and check Tutorial 17: Effusion Cooling Simulation in a 3D model combustor).
    • rohitroxkp7
      Thank you very much for your response.
    • rohitroxkp7
      Where is this tutorial available sir?
      Official Ansys Help Web Site.
Viewing 5 reply threads
  • The topic ‘Regarding Injection for Modeling film cooling in turbine blade’ is closed to new replies.
