January 31, 2021 at 11:50 am
swapniljagadale505
SubscriberRespected sir,
I am try to do same simulation which is as given ,I am unable to interpret udf , it is given error as" Parse error in line 2'" . I am attaching photo of udf also . I am using fluent in series only but while compiling it gives error as '"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64),The system cannot find the file specified."
February 1, 2021 at 4:09 pmKarthik Remella
AdministratorHello,nUDFs with DEFINE_CF_MOTION macro can only be executed as Complied UDFs. You cannot interpret these.nIf you are indeed compiling this UDF, could you please share a screenshot of the error message?nThank you.nKarthiknFebruary 1, 2021 at 4:27 pmKonstantin
Ansys Employeeto add to Karthik's comment, you should not modify a static variable in a C code. Define velx as real inside the macro.nFebruary 2, 2021 at 5:32 amswapniljagadale505
SubscriberRespected sir,n I am using fluent in series only but while compiling it gives error as 'The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64),The system cannot find the file specified.nFor that I had installed visual basic studio 2017, started ANSYS fluent from its command line but it is giving same error as above.nUdf as I had mentioned in video uploaded in your YouTube channel.I had not changed anything. Everything is as per given in video.nPlease help me nThank you,nSwapnilnnFebruary 2, 2021 at 12:29 pmRob
Forum ModeratorThe error means you've not got the compiler hooked up so that Fluent can see it. It's also that Fluent is now parallel most of the time, but you only need to parallelise UDFs if running on multiple cores and the macros require it. nPlease use 2020R2 or 2021R1 as there's an inbuilt CLANG compiler which removes the need to figure out which bit of MS Studio has been hidden/moved/changed on the Microsoft download page. nFebruary 5, 2021 at 8:08 amswapniljagadale505
SubscriberRespected sir,nThank you for your help.I had solved my problem now it is working fine.I have problem in motion of object .I want vertical motion of object .So I changed UDF but it is not working .Still its motion is in horizontal direction. I n
had done changes which mentioned above.nnPlease help me outn
February 5, 2021 at 11:00 amRob
Forum ModeratorYou've set the code to return vel[0], which means the x-direction in C language. [1] is y and [2] is z. Remember C starts at 0 when counting. Don't worry, nearly everyone either makes the mistake or asks why up is x[1]. nViewing 6 reply threads- The topic ‘Regarding error while interpreting udf file’ is closed to new replies.
Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
4167
1487
1363
1194
