Regarding automation in fluent
    • prateekbandi
      Hi,nI am doing a parametric study where I need to vary different parameters as boundary conditions for about 100 cases. Is there any way I can automate the entire process to save time and effort?n
      Yes. Check if you have Design Explorer in Workbench, or create the parameters you need to and use the parameter manager. Note you MUST set an out put parameter for the system to work.
    • prateekbandi
      Thank you for the reply. I have to simulate 100 steady-state cases where I need to vary the heat transfer coefficient, solar flux, and ambient temperature and calculate the bulk average temperature of the domain at the end. Could you please tell me how exactly I can use Design Explorer?n
      I'd start with the documentation! Re the parameter manager in Workbench, you may be able to copy & paste the input parameters from Excel so that may be quicker. n
  • The topic ‘Regarding automation in fluent’ is closed to new replies.
