June 28, 2023 at 1:35 pm
June 29, 2023 at 10:08 am
SRP
Ansys EmployeeHi,
If you want to compute reference values from the conditions set on a particular boundary zone, select the zone in the compute from drop-down list. Note, however, that depending on the boundary condition used, only some of the reference values may be set. For example, the reference length and area will not be set by computing the reference values from a boundary condition; you will need to set these manually.
For more details, you can refer to fluent user's guide: 38.12. Reference Values (ansys.com)
Thank you.
June 29, 2023 at 5:01 pm
k1465822
SubscriberThank you very much for the reply,
I do get what Reference Values section means but the problem is what does it mean by Length ? according to my 3D model i have selected INLET (surface that pointing blue arrows) to initialize the computation. So as for the Length value, what should i put because INLET is just a surface that airflow come in to my 3D model domain.
June 30, 2023 at 7:42 am
SRP
Ansys EmployeeHiÂ
For the reference length it should be approximately the length of your geometry that is normal to the designated flow. You can try entering projecting length.
Thank you.
July 3, 2023 at 12:04 pm
July 13, 2023 at 9:08 am
SRP
Ansys EmployeeHi,
Yes you can continue running simulation.
July 13, 2023 at 9:51 am
k1465822
SubscriberSure, thank you very much for the clarification.
- The topic ‘Reference Values in Fluent’ is closed to new replies.
5654
1890
1414
1303
