December 17, 2024 at 6:06 amthamilmaniSubscriber
I am running a heated pipe flow simulation. I impose a cp property through a set of piecewise linear profile.
How is the reference enthalpy calculated? In Reference Values, enthalpy is shown as negative for a reference temperature mentioned at inlet.
December 17, 2024 at 10:19 amRobForum Moderator
There's a reference temperature for phase change in the material properties. For the boundary it's against 298.15K, there is a value set in the Reference Values, but I'd need to check if that also effects the flux reports: try it and let the Forum know.Â
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
802
599
591
366
