Reference temperature for instantaneous coefficient of thermal expansion
    • SaiD
      Why do I have to input the reference temperature in the material's instantaneous coefficient of thermal expansion?n
    • Cheta Rathod
      Thermal expansion is explained in Section 3.5 of the MAPDL Material Reference Guide.nnIf a secant CTE is defined (alpx), the thermal strain is CTE*(T-TREF). If an instantaneous CTE is defined (ctex), then it is converted to an equivalent secant CTE. That conversion uses TREF. The thermal strain is then calculated as the equivalent secant CTE*(T-TREF).n
  • The topic ‘Reference temperature for instantaneous coefficient of thermal expansion’ is closed to new replies.
