April 22, 2024 at 8:06 am
yusuf uzun
SubscriberHi,
I am using Semi-Mechanistic Boiling Model. It says, Â in theory guide, that the nucleate boiling heat transfer coefficient is calculated using the Forster and Zuber correlation. There are several fluid properties in this correlation. At what temperature are these properties calculated? Bulk temperature or something.
April 22, 2024 at 9:25 am
Forum ModeratorI'm fairly sure most are wall or near wall cell values, but if it's not clearly stated in either the manual or references I'm not able to comment in detail. You may want to read the 24R1 Fluent Beta options too.Â
April 29, 2024 at 2:40 pm
yusuf uzun
SubscriberThere is no explanation about at what temperature the liquid properties are calculated( thermal conductivity, density, viscosity...) in Theory or User Guides.
April 29, 2024 at 3:23 pm
Forum ModeratorCheck the model advanced settings - it's based on those.Â
April 30, 2024 at 7:19 am
April 30, 2024 at 9:04 am
Forum ModeratorTo the left of the highlighted block - Boiling Model Reference Quantities.Â
May 2, 2024 at 8:39 am
May 2, 2024 at 1:11 pm
Forum ModeratorLooks like there are a few places to get the various equations & notes, and not every model will be specifically mentioned in every place.Â
- The topic ‘Referance Temperature of The Nucleate Boiling Heat Transfer Coefficient’ is closed to new replies.
6019
