TAGGED: outres, result-file-size, thermal-electric, transient-analysis
January 6, 2022 at 9:58 am
m_gonser
SubscriberHello together,
i am running a transient thermal-electric simulation with about 5000 Steps (7000sec). As the data size is huge i tried to reduce it. (Approximately 211GB for all steps )
The "Output Controls" options are not working due the thermal-electric simulation.
January 6, 2022 at 4:11 pmAshish Khemka
Can you check how often (that is, at which substeps) are you writing the solution results item? Please refer to the following article which might help:
Reducing the Size of your RST FileÔÇôOUTRES is your Friend ÔÇô PADT, Inc. ÔÇô The Blog (padtinc.com)
Regards Ashish Khemka
January 6, 2022 at 4:37 pmm_gonser
thank you for the response! Yes, I referred to the link you sent.
in the sulution information, in the beginning, the default value is the following:
Then i try to overwrite the output control table, with the code above, which seems to work at first:
But at all the following load steps, the output control options are overwritten again
January 6, 2022 at 6:39 pmChandra Sekaran
Ansys EmployeeIf you are using Mechanical, set the "Step Selection Mode" to 'ALL'. The default is FIRST. So the outres commands may be getting executed only for the first load step.
Also I like including outres,all,none like below
OUTRES,ERASE
OUTRES,all,NONE
OUTRES,FMAG,LAST
OUTRES,EHEAT,LAST
OUTRES,ETMP,LAST
OUTRES,EPTH,LAST
OUTRES,STAT
January 7, 2022 at 11:09 amm_gonser
Thank you, it was the "Step Selection Mode" setting.
Now it is working and i can test, which items are useful for my case.
Problem solved, thank you!
Viewing 4 reply threads- The topic ‘Reducing Result File Size in Transient-Thermal-Electric Simulation’ is closed to new replies.
5664
1890
1419
1304
