July 3, 2024 at 2:03 am
handon
SubscriberHello, I found that light interference usually happens in the simulation of finite-thick solar cells, causing oscillation in the reflectance graph. This is especially severe when they are coated with semi-transparent materials and structures.
How can I reduce the Fabry–Pérot interference?
The solar cell structure is like below:
-     Si substrate thickness = 150 μm
-Â Â Â Â Â The SiNx layer is coated for the front and rear sides.
-Â Â Â Â Â The MD600 (a kind of polymer material) hyperbola structure is formed for the front and rear sides. Â
July 4, 2024 at 7:56 pm
Guilin Sun
Ansys EmployeeThis is a duplicate of this post  https://innovationspace.ansys.com/forum/forums/topic/how-to-reduce-the-fabryperot-interference/
- The topic ‘Reduce Fabry–Pérot interference’ is closed to new replies.
