Rebar cage analysis. How do I keep the bars connected?
    • Jaclyn Mafo
      I'm working on the analysis of a rebar cage. The connections have been modelled as Bushing joints to allow the experimental translational and rotational stiffness values to be defined. Contacts have been suppressed and I've performed a deformation analysis. As shown below, the vertical reinforcements pass through the stirrups. How could I prevent this?
      Thanks
    • John Doyle
      Can you try adding edge-to-edge contact with CONTA177 elements?
  • The topic ‘Rebar cage analysis. How do I keep the bars connected?’ is closed to new replies.
