February 12, 2024 at 3:39 pm
md nur alam mondal
SubscriberHi, Is it possible with Ansys Fluent to model reacting flow with LES using finite rate chemistry? If possible, what are combustion models are available to deal with this?
February 12, 2024 at 4:29 pm
Forum ModeratorReacting flow & LES, yes. The documentation will cover which models are available.Â
February 12, 2024 at 6:21 pm
md nur alam mondal
SubscriberThank you so much for quick reply. For finite rate chemistry, EDM is mentioned as an option for LES. But there is nothing said about std EDC or PaSR EDC though the documentation cites one of the LES papers as a reference. However, is it possible to use EDC for LES?Â
February 13, 2024 at 9:58 am
Ren
Ansys EmployeeYes, all Fluent combustion models are compatible with LES. You can find the informaton in the Fluent user guide Appendix A Ansys Fluent Model Compatibility.
February 13, 2024 at 10:19 am
md nur alam mondal
SubscriberNow it is clear to me. Thank you, very much appreciated.
- The topic ‘Reating flow modelling with LES’ is closed to new replies.
