TAGGED: #fluent-#cfd-#ansys, profile, profile-file, pump, pump-impeller
August 29, 2024 at 4:25 pm
javat33489
SubscriberHello everyone.
I would like to return to the calculation of the centrifugal wheel and writing/reading the profile.
When I write/read the profile, it is written but not read and returns an error.
I described in detail how I did it. I also attached the file of the recorded profile. Please take a look, help.
The wheel looks like this:1. Assign the profile record to the outlet:
2. Perform the calculation, wait for convergence:
3. Read the profile:
4. Specify the offset of the recorded profile from the outlet to the inlet:
5. Set the recorded profile to the boundary condition of the inlet:
6. Perform initialization.
Run the calculation.
We get an error:Profile file:
August 29, 2024 at 4:44 pm
Forum ModeratorPlease post the contents of the file as staff are not permitted to open/download anything. Why are you writing the profile before running the model?Â
September 2, 2024 at 4:05 pm
javat33489
SubscriberSir, I assigned a file for recording and ran the calculation, as a result of the calculation, the data was written to it. Did I do something wrong?
Sir, I can't publish the profile file, there are 6000 lines.
September 9, 2024 at 9:29 am
Forum ModeratorIn which case, can you post the first few lines of the file? Profiles tend to be a "write once" set up, so I wouldn't expect anything to be automated.Â
September 12, 2024 at 6:54 pm
October 12, 2024 at 8:39 pm
javat33489
SubscriberSir?
October 14, 2024 at 9:51 am
Forum ModeratorThat looks OK. Does that x-position agree with the inlet?
October 17, 2024 at 6:18 pm
October 18, 2024 at 10:30 am
Forum ModeratorLooks OK. Build a very simple model, eg a pipe. See if that works.Â
5934
1306
