October 30, 2024 at 7:13 pm
johannes.haataja
SubscriberI believe the readdata script command is not working properly, or more precily, cannot read decimals and scientific notation.
For instance using the example testfile.txt:
Time Value
0.0 3.2e-6
1.0 2.8e10
2.0 4.1e5
3.0 3.3Âprovided on the documentation page of readdata results in:
M=readdata("testfile.txt");
?M;
result:Â
0 Â 3 Â
1 Â 2 Â
2 Â 4 Â
3 Â 3I'm hoping someone could verify the issue (and I hope Ansys will fix the command ASAP).
October 31, 2024 at 12:06 am
Kirill
Forum ModeratorHello johannes.haataja,
I've just checked the script in Lumerical 2024 R2.3. Here is my result:
M = readdata("testfile.txt"); ?M;Result:
0 Â Â 3.2e-06
1 Â Â 2.8e+10
2 Â Â 410000
3 Â Â 3.3As a debugging step, try to write data to the file and then read it back form it.
Best regards,
Kirill
October 31, 2024 at 7:05 am
johannes.haataja
SubscriberÂ
Much obliged Kirill for your help,Â
 I don’t know why I get different behavious. I’ve replicated the issue on Lumerical 2024 R2.2 and R2.3 on two different Ubuntu systems.Manipulating elements of M inside Lumerical to haveÂ
0 Â 3.2e-06 Â
1 Â 2.8e+10 Â
2 Â 410000 Â
3 Â 3.3ÂÂ
then using write function
write('writetest.txt',num2str(M),'overwrite');
M2 = readdata('writetest.txt');
?M2;
result:Â
0 Â 3 Â
1 Â 2 Â
2 Â 410000 Â
3 Â 3
Perhaps as temporary solution, I'll multiply the values of my data file by some large enough prefactor and then divide M by the same prefactor to get the desired outcome. -
November 1, 2024 at 6:34 pm
Kirill
1. Check if the data is being saved correctly. What output do you get in writetest.txt when you open it manually in a text editor? Also consider formatting the data while saving it to the file; see format and num2str functions.
2. I’m not sure if this is relevant in your case, but you can use MATLAB (.mat) files to save and load data. Check out the matlabsave / matlabload functions.
3. The Lumerical Data File (LDF) format might be another option; consider the loaddata / savedata functions.
4. Double-check the System Requirements and Ubuntu Linux installation guide.
Best regards,
Kirill
5939
1307
