Read result from projectscratch folder
    • deepmech.maurya
      Hello
                i run a simulation in ansys static structure. Before starting, information is fed for saving each step.
      analyses setting> restart control> all(for all options)
      By mistake file is closed forcefully. There is 73 GB project scratch folder is there.
      How to read result from there ?
      regards
      Deepak maurya
      I don't think you can recover anything from this situation.
      You may have to delete the scratch folder and start solving from the beginning.
    • deepmech.maurya
      Hello sir
                   means again 43 hours to run.
      Its ok
      thanks
  • The topic ‘Read result from projectscratch folder’ is closed to new replies.
