April 13, 2021 at 3:17 pm
cbur
SubscriberHello,
One of our customers has a problem launching spaceclaim. It asks to open in read-only mode.
After trying the command line as an admin (and as a non-admin) it still doesn't work.
This customer told me that the problem had already occurred at the end of last year and that someone from ansys had taken over his computer (link to the corresponding ticket: Spaceclaim 2020 R2 not launch )I enclose pictures of the command lines in error
Do you have an idea?
April 14, 2021 at 7:53 am
Naresh Patre
Ansys EmployeeHello charlie
Can you ask the customer's IT team to allow access to the certificate check URL:   ocsp.digicert.com and then try again?
April 27, 2021 at 8:41 am
cbur
SubscriberNaresh Patre Hello,
Sorry for the delay in answering.
After allowing the address ocsp.digicert.com in the webfilter of their fortigate, there is no improvement... do you have another suggestion?regards
April 27, 2021 at 9:55 am
Naresh Patre
Can you please send all the latest files from section 6 of below mentioned article:
Discovery License Activation Troubleshooting - Knowledge Base - Ansys Discovery Forum
May 21, 2021 at 2:45 pm
cbur
SubscriberNaresh PatreÂ
Sorry for the late reply on this ticket.
I am attaching the curl file by mail that we managed to extract.
We have a problem with the curl: a certificate does not want to pass: cacert.pem Â
The client will solve this problem by next week so I will come back to you then.
I join you all the same the .log files which we succeeded in recovering to see if on your side you can direct us on a possible solution so that Spaceclaim can be activated.
May 27, 2021 at 2:38 am
Naresh Patre
Ansys EmployeeThe problem was caused by an update of their firewall which they didn't know about and therefore the certificates were not up to date
- The topic ‘read-only Sc’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Data Center Simulation
- DXF file loaded incorrectly
- Inventor 2025 files
- Ansys SpaceClaim and Discovery 2024 Facet shelling bug – 2022 version is better
- [SpaceClaim] STEP file size using Converter.exe
- Spaceclaim 2024 error FNE activation failed
- How to do the snap fit insertion FEA?
- Ansys Discovery Crashing vGPU (Reproducible)
2202
918
599
591
494
