March 8, 2022 at 1:17 pm
ahmed8001
SubscriberMarch 8, 2022 at 2:21 pmSurya Prakash
Ansys EmployeeHey Read only configuration occurs when we open mechanical without a license, hence in your case it is a licensing error. Can you please check your license or close and restart the software?
Thanks.
Surya
How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
Rules & Guidelines ÔÇö Ansys Learning Forum
March 8, 2022 at 2:24 pmahmed8001
SubscriberDear Surya, I have the student license may I know what I should do?
March 8, 2022 at 2:31 pmSurya Prakash
Can you try restarting the machine and workbench and see if that works? If not, the ideal solution would be reinstalling the software.
Thanks Surya
March 8, 2022 at 4:13 pmahmed8001
Subscriberok thank you
March 9, 2022 at 2:30 amdinhan0394
SubscriberIt's related to license.
You should turn off another Mechanical window before open new (only one Mechanical window at a time)
March 9, 2022 at 6:27 amahmed8001
Subscriberya it worked thank you so much
Viewing 6 reply threads- The topic ‘Read only’ is closed to new replies.
5719
