Read data from txt with apdl commands inserted in tree
    • Luiza Oltean
      Hello everyone!
      I'm working in workbench mechanical (2022r2) in a coupled field module. I want to insert apdl commands in the tree to read a table and interpolate to get some results.
      I have a file (txt with values separated by comma)with element ids and for each element i have temperature and two parameters defined. Separately i have a 3D table with a result(val) based on temperature and the two parameters. !
      So in the table the value is defined as val1(param1,param2,temp).
      How can i read my file and interpolate on the table with apdl commands inserted in the tree? I am new to apdl.
      Is there a way to do this with mechanical scripting?
      /INQUIRE,numlines,LINES,'test_complete','txt'
      *DEL,mytable,,NOPR
      *DIM,mytable,TABLE,numlines,4 ! table array to hold data
      *TREAD,mytable,'test_complete','txt','',,
      this is what i used. i know it's not defined properly but i can't figure out how to define it.
      Any help is much appreciated!
    • Ashish Khemka
      Please see if the following links help:
      External Data (ansys.com)
      How to access the ANSYS Online Help
      Also, search internet for topics titled:
      The *TREAD Command and Comma-Separated Values (CSV)
      Using External Data in ANSYS Mechanical to Tabular Loads with Multiple Variables
      Please see if these help.
      Ashish Khemka
  • The topic ‘Read data from txt with apdl commands inserted in tree’ is closed to new replies.
