3D Design
3D Design
Reaction forces at Hinge or Cylindrical supports
    • garias
      I've got a model with two supports one is fixed and the second one is cylindrical, when I ask for the reaction forces it only gives reaction at the fixed support and 0 on the cylindrical one, I've also tried with hinge but same output. (using 2019 R1)
        Any idea why?
    • Brian Bueno
      Gabriel Arias
      I'll have to inquire with the development team about this.  The results don't seem to be accurate, although in some cases you should make sure the calculation is not reporting a sum of the values if the result will have components in opposite directions.
      • garias
        Brian Bueno
        Hi Brian,
          Do you have any update on this issue?
        Thanks a lot for your help
      • Brian Bueno
        Gabriel Arias
        At the current point in time the reaction resultant will only be reported for a fixed support.  Other supports will show 0 N.  We're working to improve the support types that are accepted by the calculators.
    • garias
      Thanks a lot for your reply, I keep an eye on the next releases
  • The topic ‘Reaction forces at Hinge or Cylindrical supports’ is closed to new replies.
