September 26, 2024 at 9:00 am
maori.cabanes
SubscriberI'm using the RCWA solver. I'm working on an application where I need to study the transmission under different angles of incidence. For now I'm doing some tests just using a simple surface (1.0 index). When I apply a theta angle I can't see the tilt of the field on the monitor. Am I missing something ? Thank you.
September 27, 2024 at 3:24 pm
Guilin Sun
Ansys Employeetested, confirmed. it seems it only counts the phase in one direction. We will investigate more.
October 2, 2024 at 7:43 am
maori.cabanes
SubscriberThank you for your answer. But do the other results (grating characterization for example) really take into account the angle of incidence ?
October 2, 2024 at 5:11 pm
Guilin Sun
Ansys EmployeeIt should. you can compare the RCWA result with stackrt.
