November 9, 2023 at 1:55 pm
Marvin
SubscriberWhen installing the add-on rbf-morph issues arise when trying to access it in fluent.
The installation guide has been followed however after successful fast-loading it gives me the following error message:
Fast-loading "E:/ANSYS Inc/v222/fluent/fluent22.2.0/addons/rbf-morph/radial_basis.bin"
Done.
Done.
Error: EOF in string read
Error Object: ()"
What is the problem and how do I resolve it?
Best regards
November 14, 2023 at 2:35 pm
George Karnos
Ansys EmployeeIf you rename %APPDATA%\Ansys\v222 to v222.old
Then try to run, does it run?
Is everything installed under:
E:/ANSYS Inc/v222/ -
November 21, 2023 at 12:02 pm
Marvin
SubscriberI have tried that also and it does not find the path then!
Correct, everything is installed under this path: E:/ANSYS Inc/v222/
Only the .fluent file is located in another folder
- The topic ‘RBF Morph installation problems’ is closed to new replies.
5804
