December 19, 2024 at 11:43 am
laxyazomato
SubscriberI am trying to simulate two links problem, where in firstcase i) :Â Applied the rotation (rad) to the link 'A' (which have revolute pair with ground) and got the constraint moment at that joint.case ii). Now giving constraint moment which I got from case (i) as input for case (ii). But not getting expected result (i.e. rotation which given to the link 'A' in case (i)).Â
In this scenario, giving "A" as input and getting "B" as output, now if I am giving "B" as input then I should get the "A" as output ?Â
Input 'A' for the green link (shown below) which have revolute pair with the ground.
Output from above input
Output in case (ii)
December 22, 2024 at 7:55 pm
peteroznewman
SubscriberYou have two links, but it is not clear which end of which link is the revolute to ground.
Is there a gravity load? You have not fully described the problem.
December 23, 2024 at 6:28 am
December 23, 2024 at 6:24 am
laxyazomato
SubscriberÂ
1890
1419
1304
